15" 2000w og Mono 2000w----Skipti á 16-17" felgum fyrir E36
Postby Fenýlalanín » Thu 18. Dec 2008 00:08
http://www.live2cruize.com/spjall/showt ... hp?t=81847
Er með til sölu Power Acoustik græjur
15" keila í portuðu boxi úr 19mm MDF 40cm Hæð x 44cm Dýpt x 70cm Breidd. boxið er óteppalagt.
Class D mono magnara
Hvorutveggja eru 2000w Max
Notað í tvo mánuði
70.000 kr.- eða skipti á felgum fyrir '93 318i
FUBAR-15W
2000 watts power handling
1000 Watts RMS
250 oz. magnet size
2.5¡± BASV voice coil
SPL 93 dB
Fs: 29.9 Hz
Vas: 4.45 cu.ft.
Qms: 6.7 ? Qes: 0.52 ? Qts: 0.483
Xmax: 0.52"
Sealed box: 2.25 cu. Ft.
Ported box: 3.4 cu.. Ft.
Tuning: 39 Hz
Port Size: 4¡±(dia)x10.5¡±(length)
# of ports:2
Mounting Depth: 8.0¡±
GOTHIC CLASS D SERIES COMMON FEATURES
• Hi Speed Digital Circuitry
• Fully Regulated PWM Power Supply
• Four Way Protection Circuit
• 1 Ohm Stable
• Bridging Synchronization
• Variable Low Pass 50Hz-150Hz
• Variable Subsonic Filter 15Hz-40hz
• Variable Subwoofer EQ @ 45Hz
• Phase Switch 0-180
• Remote Dash Mount Low Level Gain Control With Cable
• Frequency Response: 15Hz to 150hz
• S/N Ratio: 100 db
• THD: 0.5%
• System Distress Indicator
• Inputs Sensitivity: 200mv-8v
• Dual Mono Speaker Output Connectors
• Platinum Plated Heavy Duty Power & Speaker Terminals
BMW 318i E36 '93
Fenýlalanín
Re: 15" 2000w og Mono 2000w
Postby Fenýlalanín » Fri 27. Mar 2009 09:03
skipti á einhverjum flottum 16-17" felgum með dekkjum...
BMW 318i E36 '93
Fenýlalanín
Re: 15" 2000w og Mono 2000w----Skipti á 16-17" felgum fyrir E36
Postby athalex1008 » Sun 29. Mar 2009 15:56
er með original 16" álfelgur ef þú ert til í skipti
athalex1008
