Intercooler
Intercooler
Postby Einarsss » Tue 17. Jun 2008 23:32
upplýsingar :
Length 27"
Height 6"
Thickness 2.5"
Inlet 2.5"
Outlet 2.5"
Compress Air Flow Rate <600Cubic Feet/Min, Rated to 300-400 Max HP
Working Pressure: 35~40PSI
Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32 °F~302 °F (0 °C~150 °C)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 11 lbs
Ástand: notað
Verð: 7 þúsund
