Kenwood - KDC-PSW9531Y,Geðveikur Bílgeislaspilari til sölu..
Postby Roark85 » Sat 30. Sep 2006 11:30
Er með til sölu flottasta bílaspilaran frá Kenwood..
4x50w,3x 5v RCA preouts,1 RCA input,acd drive,mp3/wma.
Angle í fronti (3 stillingar)
Allar hugsanlegar stillingar í þessu tæki..
er 3 vikna gamall og ég er buin að nota hann í 2 vikur.
2 ára ábyrgð er á tækinu og ekki 1 rispa á honum.
Ég er buin að eiga alpine cde 9815rb og Pioneer 9600mp og þessi kenwood spilari skeinir sér á þeim..
Kostar nýr 84,995kr.. en fer á einhverju góðu verði..
....Verð 55Þ kr....
Uppl í s:662-6212
Mynd...
http://www.xcom-shop.ru/files/43e63c30157c82.01608280
Hérna eru allir speccarnir um tækið..
State-of-the-art model equipped with a 4096-colour OEL display offering super-high contrast and brightness, and heightened 3D realism. For complete sound control there’s a built-in DSP featuring 4-band parametric EQ, DTA, Sound Management System, and SRS WOW Digital to let you personalize sound to your own taste.
Key Features
Fully Motorized Slide-Down Mechanism with Detachable Faceplate
Multicolour OEL Display (Customizable image)
Maximum Output Power : 50W x 4, 3 Preouts (5V), Aux-in
DSP Built-in, Dual Zone Source
AAC, MP3 & WMA Decoder, 24-Bit Digital Audio Converter
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes
Faceplate Mechanism Motorized Slide Down
Angle Adjustment 3 steps
Security Code Function Yes
Key Illumination Selectable: Red or Green
Rotary Encoder & Control Knob Yes
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
IR Remote control RC-527 supplied
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
ISO connector Yes
Display Features
Display Type Multicolour(4,096colours) OEL(Organic Electro-Luminescence) Display
Display Illumination OEL(Organic Electro-Luminescence)
Display Segment Full Dot (256x64dot)
Spectrum Analyzer Yes
Dimmer Control 2 steps - automatic
Contrast Control Yes
Demo Mode Yes
Special Character Display No
Display Customize Yes
Tuner Features
RDS (PI, PS, AF, TI, Clock) Yes
Radio Text (RDS) Yes
Programme Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
ACDrive, PC Application Software included Yes
Voice Index Yes
CD Text Support Yes
CD Text with special Character Support No
Digital Audio Converter 24 bit
0 bit Mute L/R Independent
Random Function (Track/Disc) Yes
Repeat Function (Track/Disc) Yes
Scan Function (Track/Disc) Yes
Changer-Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Disc Name Preset Play (DNPS) Yes
Audio Features
Maximum Output Power 50W x 4
MOSFET Power IC Yes
Pre-out 3 Gold plated RCA
Pre-out Output Level 5V
Auxiliary input RCA
Subwoofer Reference Level Adj. Yes
Built-In Amplifier Cut-Off Yes
Dual-Zone Source & Volume Control Yes
Dual-Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System QEX (Preset & Manual Sound Control) Yes
DSP-Features
Digital System E's+ Yes
Parametric Equalizer - 4 Bands Yes
Digital Time Alignment Yes
Sound Management System Yes
SRS WOW Digital (SRS 3D/TrBass/Focus) Yes
ODD (Offset Dual Differential) D/A System Yes
Dynamic Range Control(Wide/Normal/Midnight) Yes
Connectivity
Changer Control (5L-Bus) Yes
External Option Control (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) PS Amplifiers ('02 - '06)
B.M.S.Control ('99-'01 Amps) Yes
Advanced B.M.S. Control ('02 Amps) Yes
OEM Wired Remote Control Yes
OEM Dispay Control Yes
2-way Telephone Mute Yes
Dimmer Control Yes
Tuner Specifications
FM Frequency Range 87,5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0,7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1,6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Sigal to Noise Ratio 65dB(MONO)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
CD Specifications
Laser Diode GaAlAs
Digital Filter(D/A) 8 Times OverSampling
Digital/Analogue Converter 1 Bit
Spindle Speed 1000 ~ 400rpm (CLV: 2 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0,008% (1kHz)
Sigal to Noise Ratio 110dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC ".m4a" files
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 5000mV / 10kOhm,
Preout Impedance 80Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
DSP Specifications
Parametric Equalizer - Band 1 60Hz ~ 200Hz
Parametric Equalizer - Band 2 250Hz ~ 1kHz
Parametric Equalizer - Band 3 1,25kHz ~ 4kHz
Parametric Equalizer - Band 4 5kHz ~ 16kHz
Equalizer Gain –9db ~ 9db
Q Control 0.25/ 0.50/ 1.00/ 2.00
High Pass Filter frequency Through/30 ~ 250 (Hz)
High Pass Filter Slope -12/-18/-24 dB/Oct
Low Pass Filter frequency 30 ~ 250(Hz)/Through
Low Pass Filter Slope -12/-18/-24 dB/Oct
Time Aligment 0 — 610cm(5 cm step)
General Specifications
Operating voltage 14,4V (11 ~ 16V Allowable)
Current Consumption 10A
Dimensions (WxHxD) 182 x 53 x 155mm
Weight 1650gr
BMW:
E90 320D M/// 2,0L Big Turbo (my05)
E53 X5 4,4L Sport V8 (my01)
E46 318i AC-Schnitzer 2,0L (my03)
E38 750ia 5,4L V12 (my98) (Induvidual)
E34 520i 2,0L (my95)
E39 540i Touring M 4,4L V8..(my98)
E34 M5 3,6L(my91)
E28 528i 2,8L (my84)
Roark85
