Sony cd spilari [Seldur]
Postby Svezel » Sat 03. Dec 2005 11:14
Þarf að losa mig við Sony CDX-C6750 geislaspilara sem var í bíl sem ég keypti
Features
SSIR-EX : An improved version of the SSIR FM front end which offers better sensitivity, selectivity, capture ratio and stereo separation specifications.
STATION MEMO A CUSTOM FILE : feature that allows the user to assign an eight character name to a tuner frequency.
Best Tuning Memory (BTM): A feature in which the tuner selects radio stations by signal strength and assigns them to presets in numerical order according to their frequency value.
Active Servo Control : A proprietary Sony technology for CD and MD players. A circuit which monitors tracking and focus functions, among others, and actively adjusts those functions for optimal performance.
Repeat : A feature that plays a track or song over and over.
Shuffle Play : A feature which employs random selection from available tracks.
CD/MD Control : The ability of a component to operate a CD or MD disc changer.
CUSTOM FILETM : A feature package that provides intuitive and safe source management for an audio and A/V system.
High Pass Filter (HPF) : A CROSSOVER component that blocks low frequencies, allowing higher frequencies to pass through.
Low Pass Filter (LPF) : A CROSSOVER component that blocks high frequencies, allowing only lower frequencies to pass through
D-Bass (Dynamic Bass): Sony's unique low frequency enhancement system which provides up to 18dB of gain to frequencies below 75Hz, without midrange coloration of interference.
40Wx4 High Power : Speaker level outputs driven by an amplifier, typically at least 40 watts per CHANNEL maximum power rating.
Fold Down Face : A DIN headunit whose faceplate hinges at the bottom to reveal a media loading slot. Provides a larger area on the face for the display and controls.
Rotary Encoder : A digital control which emulates the function of a "big round volume knob". Also controls additional preamp functions.
CD Text : A compact disc and player feature utilizing disc, track and artist information encoded directly on the CD media. Both playback and media components must have CD Text compatibility.
Frequency Response : 10-20kHz (�3dB)
Total Harmonic Distortion : 0.03%
Disc S/N Ratio : 90dB
Dynamic Range : 90dB
Tuner S/N Ratio : 68dB mono
THD : 0.3%
Usable Sensitivity : 8dBF
50-dB Quieting Sens : 13dBF
Capture Ratio : 2.0dB
Adj-ch Selectivity : 75dB
Alt-ch Selectivity : 75dB
3 x RCA út, 1 x RCA inn og hægt að stilla lýsingu á amber (svipuð bmw lýsinguni)
Verð 8000kr
Seldur
Svezel
