Magnaður græju pakki fyrir kröfuharða. ALLT SAMAN SELT !!
Postby AnyKey » Mon 11. Apr 2005 14:31
Jæja hérna er eitthvað fyrir þá sem vilja fá alvöru græjur. Þessar græjur eru í 100% topp standi. Var að selja bílinn minn og hef þá ekki lengur not fyrir þetta. En þetta eru geðveikar græjur sem ég mæli 100% með.
Bíltæki: Clarion DXZ928R
50W x 4
Ce NET
AC Processor II
Dolby Surround Pro Logic II
Remote control of Projection
Cd-r/cd-rw
ISO Connector
Rds-eon
4V HVO
Combination of Reader of CDs and radio Rds-eon AM/FM of High Allegiance
Rds-eon receiver with controller for disqueteiras of DVDs, CDs, MDs, DVD Decks, 5.1 Decoder of and Tuner of TV and DAB;
Processor II of CA: DAC of 24bits, regulation of time, Intensifier of Virtual Space, Dolby Pro Logig II and P.EQ.;
Pull-out aluminum panel with motorized inclined console of double mechanism.
Rotating Coder;
Double Illuminated Keyboard key (Green or Red Illumination);
Liquid crystal counter of multiple and multicolored window of high visibility;
6 exits of gilded row pitch RCA of 4 Volts and 1 entrance RCA AUX of 2 canals with adjustments of 3 levels.
Keilan: 2x DLS 12" NW 112
Image Image
Impedance: 4 ohm
Size: 12" (30 cm)
Power handling capacity: 350 W RMS / 550 W max
Frequency range: 20-2000 Hz
Sensitivity: 90 dB (1W/1m)
Magnet size: 180 mm (7,1"), 70 oz
Outer diameter: 310 mm (12,2")
Installation depth: 122 mm ( 4,8")
Mounting hole: 282 mm (11,1")
Weight: 6,5 kg (14,3 lb
X-max: +- 9 mm (0,35")
Fs: 31,8 Hz Re: 3,34 Qes: 0,31 Qms: 1,71 Qts: 0,26 BL: 16,35 Vas: 58,8 l (2,08 cuft)
Magnarar: 2x Crunch USA P4175
Magnarar:
THIS AMP IS TRULY AWESOME! 4/3/2 CHANNEL OPERATION! Separate base/treble controls, 12 dB variable crossover network. Line output for amp daisy-chain. Class AB operation. High speed MOSFET. "Flow Through ZONE KOOL" heat sink. PWM MOSFET power supply.
- High Power 4 X 175 Watts @ 4 Ohms
- 4 x 350 Watts @ 2 Ohms
- 2 X 700 Watts @ 4 Ohms Bridged mono
- Full MOSFET Design
- 4 & 2 Ohm Stable
- PWM Power Supply
- Tri-Mode Capable
- 12 dB per Octave internal crossover
- Bass/Treble Switch
- Brushed Aluminum Heat Sink
- On-board diagnostics
Hérna er svo myndir af boxinu:
Er ekki alveg viss hvað ég vill fá fyrir þetta en það verður allavega ekkert brandraverð .. enda keppnis græjur. Þannig að ef þið hafið áhuga komið þá með tilboð sem ég get ekki hafnað og ég mun skoða málið. Þess má geta að bíltækið kostaði bara 89.000.- Þegar það var keypt.
Getið náð í mig hérna eða email: gretarmar@gmail.com eða GSM: 892-0734
AnyKey
Postby AnyKey » Thu 21. Apr 2005 00:13
Ég nenni ekki að hanga með þetta lengur ...
Bassaboxið með mögnurunum á 50.000 kr.
Bíltækið á 25.000 kr.
Þið fáið ekki eins öflugt og fullkomið tæki fyrir þennan pening. Það er líka með Aux tengi.
AnyKey
Users browsing this forum: Majestic-12 [Bot] and 10 guests
