It is currently Fri 01. Aug 2025 07:48
PostPosted: Wed 30. Jul 2025 02:44
Mounted combat in Elden Ring can feel both exhilarating and unwieldy—especially when you’re facing down dragons or chasing down rune bears across the open fields of the Lands Between. Whether you're still fumbling with Torrent's reins or trying to optimize your battle efficiency while on horseback, this guide offers 20 practical tips to help you take full control of mounted combat and emerge victorious.
1. Use Hit-and-Run Tactics
Don’t stick around after landing a blow. Hit your enemy and quickly ride out of range to avoid counters. Mounted combat is all about mobility.
2. Equip Lightweight Weapons
Lances and greatswords may look cool, but faster weapons like spears and curved swords are often more effective when riding Torrent. Their quicker animations allow you to strike more often while staying agile.
3. Master Directional Attacks
Use the left and right attack buttons deliberately—left triggers strike on the left side of the horse, and right triggers attack on the right. Knowing this helps avoid swinging into thin air.
4. Buff Before Charging
Spells and incantations that boost damage or defense can be cast before entering battle. Consider using these buffs when engaging stronger enemies while mounted.
5. Dodge with Movement, Not Rolls
You can’t roll while mounted. Instead, use Torrent’s dash and jump to evade attacks. Learn enemy wind-ups so you can sidestep or gallop out of range.
6. Torrent Is Not Immortal
Your steed can take damage and even die. Always keep a Flask of Crimson Tears ready to revive him mid-combat. And remember—taking a hit while mounted deals damage to you too.
7. Use Terrain to Your Advantage
Cliffs, hills, and trees can be more than just scenery. Use them to line-of-sight projectiles, force melee enemies into bad angles, or bait them into fall damage.
8. Fight Groups Strategically
When facing multiple enemies, use Torrent to kite and separate them. Lure one away at a time, take them out, and loop back.
9. Watch Your Stamina
Galloping, attacking, and dodging all consume stamina. Always keep an eye on your bar—running out can leave you helpless in a tight moment.
10. Charge Attacks Are Your Friend
Holding down the attack button while galloping delivers a strong charge attack. It's especially effective against single targets or bosses with slower animations.
11. Use Spirit Ashes for Ground Support
Mounted combat doesn’t mean going solo. Summon Spirit Ashes to distract enemies while you chip away from horseback.
12. Respec If You’re Torrent-Heavy
If you find yourself fighting mounted more often than not, consider tweaking your build to favor Dex and Endurance. These improve both attack speed and stamina management while riding.
13. Stay Clear of Indoors
It may sound obvious, but don't underestimate how many times players charge into a ruin or corridor while mounted and get stuck. Dismount before entering tight spaces.
14. Use Ranged Weapons on the Move
Bows and crossbows can be used while riding, making them excellent for pestering enemies from a distance without closing the gap.
15. Avoid Heavy Armor
Unless you're confident in your mobility, consider wearing medium or light armor. Speed is more crucial than poise in most mounted encounters.
16. Experiment With Elemental Damage
Many enemies have elemental weaknesses. Try different weapon buffs or elemental-infused weapons while mounted—you’ll notice the difference.
17. Don't Ignore Item Crafting
Crafting fire pots, bone darts, or sleep pots gives you extra tools for mounted combat. They’re useful for softening up targets before diving in.
18. Farm Smart, Farm Fast
Some of the best rune farming spots require fast travel and mounted speed. Mastering Torrent helps you grab Elden Ring runes for sale—figuratively—by mowing through enemies efficiently.
19. Scout with Speed
Torrent isn’t just a combat mount. Use him to quickly scout dungeons, enemies, and paths. It’s often safer than going in on foot.
20. Stock Up at the Elden Shop
The elden shop vendors scattered throughout the world sell items and gear that enhance your mounted combat potential—like throwing weapons, lightweight swords, and Torrent-boosting gear. Visit them often.
Mounted combat isn't just a side mechanic—it's a core part of how Elden Ring encourages you to engage with its vast world. With a bit of practice, some strategic preparation, and the right gear, you’ll be galloping across the battlefield like a true Tarnished knight.
