Display fyrir E30
Display fyrir E30
Postby bimmer » Wed 03. Aug 2011 23:41
Oliver, einn af þeim sem vann í RNGTOY, er búinn að þróa með félaga sínum helvíti flott display fyrir E30 -
held að fyrsta útgáfan sé bara fyrir þá sem eru með S54 eða S62 swöpp (Einar.... :naughty: )
Tekið af: http://www.s14.net/forums/showthread.php?t=52416
"Hello,
as here are meanwhile a lot of S54 or S62 engine swappers I want to show you guys a nice part.
I developed this together with a friend. This displays shows you informations from the DME which will be read via Bus... wiring is so very easy...!
Sorry, this one only works with the stock DME (also with the reprogrammed ones *g*).
The displays fits the left vent in the center console of the dashboard, the same as the Alpina instruments uses....
Here are some pictures, the language is in german, but easy to understand:
G-meter (built-in G-force sensor and GPS sensor); voltage and oiltemperature
coolant temperature, oil temperature and intake air temperature
exhaust temperature, coolant temperature and throttle angle
voltage of front lambda sensors
rear (after kat) lambda sensors in volt
This display can be upgraded with an external box which will read the following things (via sensors which will be provided including the harness):
- oil pressure
- fuel pressure
- gearbox temperature
- differential temperature
I do not have pictures of these, but they look the same as above... (2 values on one page.
The display is a touch screen. The switching between the pages is done by touching the display...
The brighness can be adjusted in the settings...
Best regards,
Oliver"
"Hello,
thank you! Nice one with a lot more functions than the Alpina one... and at least available :-)
I can make the contact as the seller is a friend...
The price is 600 Euros for the basic display (showing the shown pages with the aluminium housing; perfect fitment in the left vent at the center of the dashboard) including small harness and instructions for the install (very easy!!!).
The optional extension box costs 300 Euro including harness and all sensors/adapters needed for installation... (and also instrcutions)...
I can give support as the sellers english is not really good :-)
Best regards,
Oliver"
Re: Display fyrir E30
Postby jens » Thu 04. Aug 2011 00:10
Dam, þetta er vel gert :thup:
Postby Einarsss » Thu 04. Aug 2011 08:17
Þetta er bara töff 8)
Postby rockstone » Thu 04. Aug 2011 09:55
bara e30?
rockstone
Postby Mazi! » Thu 04. Aug 2011 11:24
rockstone wrote:bara e30?
nananabúbú :mrgreen:
Postby Alpina » Thu 04. Aug 2011 19:52
MEGA flott ..........................en 600€.................... :shock:
er það bara ok ????
Postby bimmer » Thu 04. Aug 2011 20:13
Alpina wrote:MEGA flott ..........................en 600€.................... :shock:
er það bara ok ????
TEAM BE.....;;;;;;;;;::::::::::::::::::::::,,,,,,,,,....................... EKKI wannabe.
Já þetta kostar en þetta er SEHR SONDER og ekki mörg eintök smíðuð.
Postby Alpina » Thu 04. Aug 2011 20:18
Þórður,,, 600 euro eru 100.000 iskr GRUNNVERÐ
og þá er eftir tollar osfrv,,
ég er ekki að segja að þetta sé ekki þess virði en samt HELLINGUR
Postby bimmer » Thu 04. Aug 2011 20:20
Alpina wrote:Þórður,,, 600 euro eru 100.000 iskr GRUNNVERÐ
Þýðir ekkert að miða við verðlausar ísl. krónur......... þetta er ónýtur gjaldmiðill.
Postby Alpina » Thu 04. Aug 2011 20:22
Þórður ef þú ert svona mikill spaði ,,, af hverju ert þú ekki á slaufunni :shock:
Postby bimmer » Thu 04. Aug 2011 20:25
Halló - var ég ekki að segja að krónan væri ónýt?? Ég fæ borgað í krónum.
Postby Alpina » Thu 04. Aug 2011 20:26
Veit,,,
Postby maxel » Sat 06. Aug 2011 01:58
Þetta er mega töff, leiðindi með að þetta er s54/s62 only, væri ekki ónýtt í ringtoy
