Um nýju fimmuna og nýja E Benz....
Postby bebecar » Fri 20. Feb 2004 15:32
Or will you? Yes, the new 5-series is unpleasant to behold and yes, its steering is a bit weird, but what else can you buy for this sort of dosh? You can’t have a Mercedes because it’ll break down all the time and the dealer won’t be able to fix it. The Audi A6 is on its last legs. The Saab 9-5 is mad. The Lexus is dull. You won’t pay £30,000 for a Volkswagen. And I’m sorry but if you’re worried about aesthetics you’re hardly likely to go for an S-type Jaguar.
http://www.timesonline.co.uk/article/0,,3801-933599_2,00.html
Ég þori varla að pósta þessu á stjörnunni en svona eru allair ritdómar þar sem ég les um Benz, var að lesa annan eftir Jeremy Clarkson þar sem hann sagði að stærsti stafli af kvörtunum til Top Gear væri frá Benz eigendur kvartandi yfir bílunum sínum.
Í prófun í EVO dó SL bíll í reynsluakstri á 150 km hraða - fór svo í gang nokkrum sekúndum síðar en þetta var víst skelfilegt móment!
Best að halda sig bara við gömlu góðu Benzana ef maður er í pælingum sennilega.
Postby bebecar » Fri 20. Feb 2004 16:20
Reyndar er mikill sannleikur í þessu hér líka og þessvegna líkar mér betur við gamla bíla en nýja... ´
All modern cars isolate you from the road, they cocoon you in a safe, quiet, world of velour and Radio 2 and air-conditioning. The wind that ruffles your hair in a modern convertible isn’t wind at all, rather a gentle breeze that has been massaged by an aerodynamics engineer somewhere in Frankfurt. And the nice rorty little rasp from your exhaust at 5000rpm was in fact put there by someone in an anechoic chamber in Stuttgart. So when you’re in a car, you’re really in the Matrix.
En hér talar Jeremy Clarkson um Benz SL í grein sem raunverulega er um Caterham!
Postby GK » Fri 20. Feb 2004 17:22
HEHEHEHE Jeremy er snillingur
GK
Postby gunnar » Fri 20. Feb 2004 17:47
Jeremy Clarkson er helvíti flottur, ég á held ég núna orðið ALLA Top Gear þættina inn á server vél hjá mér :) Er að klára að horfa á 3 seríu sem stendur.
Postby Svezel » Fri 20. Feb 2004 18:47
Vinur minn hefur haft 2002 árgerð af E240 til umráða annarslagið og ég hef setið í þeim bíl þónokkuð en ég veit nú ekki til þess að það hafi verið eitthvað bras á þeim bíl. Þó er það nú einn af allra fyrstu E bílunum en fyrstu bílar af nýju módeli hafa hingað til ekki verið bilanafríir í gegnum tíðina.
Þó er eitt sem mér þykir mjög lélegt en það er lakkið á þeim, bíllinn er allur í litlum rispum þetta nýr og þó aldrei verið kústaður né bónaður með slæmum klútum. Það er bara ekkert gaman að keyra hann í björtu því það glampar á hann eins og vel hreystraðan fisk.
Svezel
