Ný heimasíða hjá ALPINA
Postby Alpina » Thu 11. Sep 2003 20:28
:shock: 8)
Postby Alpina » Thu 11. Sep 2003 20:29
Postby Haffi » Thu 11. Sep 2003 20:48
Me loves alpina... Mig langar svo endalaust í Alpina B8 '97 :)
Haffi W. Schnurrenberger.
Haffi
Postby Kull » Thu 11. Sep 2003 20:53
Allir Alpina fans ættu að ná sér í eintak af október blaði Total BMW, það er Alpina special issue. Margar ágætar greinar þar um skemmtilega Alpina bíla.
C32 AMG Carlsson
Toyota Land Cruiser 80
Subaru Impreza GX - beater!
Kull
Postby Haffi » Thu 11. Sep 2003 20:55
Like a big brother to the B3, the B8 is very unique because of its V8 engine. Based on the 4.4L from the 540i, it puts out 333 horsepower, 93 and 68 more horsepower than the BMW M3 and Alpina B3, respectively. 350 of its 470nm of torque are available at 1000rpm. Over 40 modifications to the engine compartment had to be made before the V8 fit in. Only 231 cars were built in its three year lifespan from 1995 to 1998 however 4 more detuned versions with a 4.0L engine and 313hp were also built and sold excusively in Japan. To achieve the bump in power and displacement over the stock engine, new engine blocks were cast by BMW for Alpina, higher compression Mahle pistons were added, the valve timing was changed, and a new exhaust system and new catalysts were fitted. A six-speed manual tranny made by Getrag is the only transmission available. Exterior differences include a new front spoiler, an optional rear spoiler, optional Alpina decals and 17in Alpina wheels. Given the huge increase in power it is very surprising to see the Alpina accelerate slower than a stock M3, but a conservative estimate may be to blame. If your main concern, however, is showing off your V8 3-series than the B8 4.6 is the car for you.
5.6 í 100... soldið slow en samt!!!
ME WANTS !
Haffi
Postby Bjarki » Thu 11. Sep 2003 21:02
Kull wrote:Allir Alpina fans ættu að ná sér í eintak af október blaði Total BMW, það er Alpina special issue. Margar ágætar greinar þar um skemmtilega Alpina bíla.
já þokkalega var að fá það sjóðheitt inn um lúguna í dag!! :D
Bjarki
E39: 540iA '98
Bjarki
Postby Alpina » Thu 11. Sep 2003 21:32
Sem sagt ég ,FANIÐ, :bow: er greinilega hálviti að vera ekki áskrifandi
Postby Bjarki » Thu 11. Sep 2003 21:35
ég get mælt með áskrift þetta er mjög skemmtilegt blað og ekki dýrt
http://www.totalbmwmag.co.uk/
Bjarki
E39: 540iA '98
Bjarki
Postby Alpina » Thu 11. Sep 2003 21:45
Sá einn gráan B3S í Niederlassung Hamburg um daginn
og hann var BARA flottur........
Ps var að kaupa mér 2 ALPINA Lykkla kippur á 15 EURO stykkið :wink:
Postby morgvin » Mon 15. Sep 2003 18:14
er hægt að kaupa blaðið á landinu ???? ef já HVAR ???
91 E34 BMW 518i
-Don't argue with stupid people they will only drag you down to their level and beat you with expirience.
morgvin
Postby Jss » Mon 15. Sep 2003 23:14
Það marg borgar sig að kaupa það bara af netinu, eða gerast áskrifandi, var loksins að gerast áskrifandi áðan. Kostnaðurinn við það er á við að kaupa ca. 3 blöð á ári hér heima, þ.e. ef það fæst hér þann mánuðinn (hef ekki skoðað blaðaúrvalið hér heima í langan tíma).
Jóhann
Jss
Postby morgvin » Wed 17. Sep 2003 19:51
en spurningin var hvar er hægt að kaupa það á landinu.
nenni ekki að standa í svona kredit korta veseni.
91 E34 BMW 518i
morgvin
Postby Jss » Wed 17. Sep 2003 20:45
Býst helst við að það fáist í Eymundsson, finnst það líklegast
Jóhann
Jss
