BMW X4
BMW X4
Postby Kristján Einar » Thu 16. Aug 2007 13:17
gæti verið sá sem við töluðum um sem X6 um daginn ... en soldið annað look á bílnum
It’s a case of X marks the spot for BMW’s future family car line-up, Auto Express can reveal.
Following hot on the heels of the upmarket X3 is a new off-road coupé, likely to be called the X4. Inspired by the forthcoming X6, the 3-Series-based four-wheel-drive model is revealed by this mule, spied testing on the roads around BMW’s German headquarters in Munich. With seating for four and a swooping body, the X4 will blend mud-plugging ability with fine on-road handling.
The sudden appearance of this car comes as a surprise, as the machine looks very different to the publicly acknowledged V3 compact MPV project, which was expected to be the next major addition to the 3-Series line-up. This mule appears to suggest that model has been dropped completely or significantly revised for greater off-road credibility.
The X4 will be offered with a wide choice of engines from the 3-Series range. Entry-level variants will feature a frugal yet powerful 2.0-litre diesel, which will be equipped with Efficient Dynamics, the manufacturer’s latest stop/start fuel-saving technology.
There will also be a range of six-cylinder units delivering up to 300bhp. But sources at BMW haven’t ruled out the possibility of an M-badged V8 version – which would be the first such car of its type.
Set to be revealed at the Geneva Motor Show next year, the X4 should hit dealers in the UK in 2009.
www.autoexpress.co.uk
Kristján Einar
BMW 2002 Turbo ´75[/url]
Kristján Einar
Postby bjahja » Thu 16. Aug 2007 13:20
Nei halló halló, þetta hlítur að vera photoshop. Framendinn og afturljósin eru BEINT af e90
bjahja
Postby ///MR HUNG » Thu 16. Aug 2007 13:44
Þetta er bara X3 í mínum augum.
///MR HUNG
Postby bjornvil » Thu 16. Aug 2007 13:48
Er þetta ekki bara upphækkaður E91 með brettaköntum?
VW Passat '98 "seldur"
VW Golf GTI '98 "seldur"
bjornvil
Postby SteiniDJ » Thu 16. Aug 2007 16:18
Eða bara leti hjá þeim sem hanna boddí á bimma. :P
Postby Jökull » Thu 16. Aug 2007 16:42
þetta er bara E91 outback 8)
BMW 325XI E46 '02
BMW X5 E53 '02
Jökull
Postby JOGA » Thu 16. Aug 2007 20:17
Jökull wrote:þetta er bara E91 outback 8)
Nákvæmlega. En er þetta ekki bara eitthvað "test mule" fyrir nýjan X3?
