Modd á nýjum bílum frá BMW?
Postby bimmer » Fri 04. May 2007 18:57
Er þetta eitthvað sem menn hafa heyrt um?
Hljómar svolítið fishy.
http://www.fquick.com/blog/BMW_Performance_Straight_from_the_Factory
"Thank you BMW for finally doing what we all want our manufacturers to offer: performance parts on the car straight from the factory. GM, Ford, Dodge - are you listening?
Coming soon, a plethora of parts will be available for new BMW 3 series owners. From 19" wheels wrapped in Bridgestone tires covering cross-drilled rotors, to strut braces and control arms. Performance wise, have them start you with a beefier camshaft, a stronger differential, and an intake/exhaust combo that will propel your car faster and raise your redline by 300 RPMs. They will even throw in a short shifter kit for those who want to slam gears.
In terms of warranty, BMW Performance parts are original BMW accessories and as such carry the full BMW Parts and Accessory Limited Warranty. If installed by an authorized BMW center at the time of a new vehicle purchase, rest assured that the performance parts are covered by the same terms and conditions as the new vehicle limited warranty.
Hopefully this will light a fire under other manufacturers' asses so they get in gear and start giving us some mods off the showroom floor. "
Postby Eggert » Fri 04. May 2007 19:22
Það er satt, þetta hljómar fishy. Vonandi er þetta satt þó... væri geggjað ef BMW færu að bjóða uppá þetta og myndi eventually auka listann af hlutum til að kaupa og þá í BMW gæðum.
E53 X5 4.4i
Eggert
Postby ///M » Fri 04. May 2007 19:26
er ekki einmitt svona í boði frá doge fyrir srt4? stage 1,2,3 performance kítti
2016 BMW X3 sDrive28i
///M
Postby iar » Fri 04. May 2007 19:50
Ætli þetta sé þá einhver millivegur á milli 320is bílsins og Mcoupe race bílsins?
Hljómar mjög vel?
Postby gstuning » Fri 04. May 2007 21:06
GM er búið að vera með svona program síðan 1950,
Þekkt sem eitt stærsta catalog af aukahlutum sem eitt
fyrirtæki hefur framleitt EVER.
Þetta gæti verið skemmtilegt
