Hefur einhver prófap blásara á 39 540 ?
Re: Hefur einhver prófap blásara á 39 540 ?
Postby fart » Thu 21. Oct 2010 06:35
Mr. Jones wrote:Maintaining the the original BMW quality, smoothness and reliability were the key factors in the VF design. This is where the GIAC software comes into full play. VF have harnessed reliability of Vortech superchargers and quality of GIAC custom software with their 10 years of supercharging experience and worldwide OEM supply contacts to create the ultimate supercharger system for the ultimate drivers car.
All key components are 100% made in California. This system has been fully road tested and dyno tuned on both the GIAC Mustang MD500AWD and in-house Dynojet 224XLC dynamometers with and without engine load. All stage 1 kits are setup at 6 psi and create as much, if not more power than similar products running greater levels of boost.
VF engineers spent over 12 months software testing the BMW Bosch and Siemens ECUs. Software flash technology and latest BMW file versions have all been employed to provide the cleanest and most reliable method of software installation. GIAC engineers extensively re-wrote the ECU software using their own binary, assembly and disassembly algorithms written from scratch. Testing the software included extensive road and dyno test cycles, with acceleration and deceleration tests for driveability smoothness and ECU fuel management. All test cars were put through long term full throttle testing in conditions varying from wet cold climates to hot dry Arizona desert temperature for safe-optimal air fuel ratios and knock activity monitoring. Competantly written ECU software has allowed VF to fully explore the potential of the BMW engine making over 40% more power in most applications.
VF chose to mount the Vortech supercharger with an in-house CNC machined aluminum bracket system. The unit is positioned in line with a bolt-on crank pulley with an additional active OEM tensioner using a dedicated serpentine belt. The key to reliable superchargers sytems is the the active belt tensioner which eliminates belt slip. The supercharger air ducts are custom molded in-house from plastic to give an OEM appearance, quality and fit. The incorporated Bosch boost overrun system is designed for smooth off-throttle cruising and deceleration with clean emmissions. The crankcase ventillation sytem is designed to cope with positive pressure and high flow OEM injectors are supplied to fit as direct replacements without modification to the injector rail. A removeable plastic air box is provided with the K&N induction filter for those who use their vechicles in persistently wet climates.The VF supercharger system remains fully OBD2 compliant and is supported by a 3 year unlimited mileage warranty on the product only. Installation can be performed in approximately 8 hours and is non-intrusive allowing it to be fully reversible.
The VF stage 2 development vehicle is aftercooled by integrating a chargecooler into a cast aluminum intake manifold included with the kit to replace the original manifold. This design approach reduces the length of pipework by about 75% required for a remote mounted chargecooler core or air/air intercooler. The simple and compact design make this kit integrate neatly into the V8s engine bay.
Every aspect of this kit has been fully engineered for high quality fitment and highly demanding performance and expectation. VF's in-house horizontal, turning and milling CNC's and plastic molding plant, GIAC's industry reputation and track record and Vortech's reliability have been fully exploited to create a product with internationally un-rivalled material technology, quality and performance.
Verð á kittinu?
Postby Mr. Jones » Thu 21. Oct 2010 07:17
Verð á kittinu?
5000 $
    E39 540i "00
    RAV4 "96
    R6 "04
Gamalt.
    Corsa gsi
    Astra gsi
    Kadett gsi
    Calibra
    Conquest tsi
    Formula 400
    Nova SS
    Vetta pacecar
Mr. Jones
Postby fart » Thu 21. Oct 2010 07:26
Mr. Jones wrote:
fart wrote:
Verð á kittinu?
5000 $
Postby Jón Ragnar » Thu 21. Oct 2010 09:52
560k
Postby Axel Jóhann » Thu 21. Oct 2010 09:58
Finnst það nú bara alls ekki svo svert miðað við included stuff.
Postby fart » Thu 21. Oct 2010 10:51
John Rogers wrote:560k
án gjalda væntanlega, flutnings, tolla, virðisaukaskatts.
Svo er install eftir, og mögulega ný kúpling.
Postby Jón Ragnar » Thu 21. Oct 2010 11:19
Þetta fer langleiðina í kannski 800k
Postby BlitZ3r » Thu 21. Oct 2010 11:38
Skella sér í helgarferð til bna og koma svo með þetta í töskunni
Björgvin Hlynsson. S.6636835
Bmw E34 525iXa '94
MMC Pajero 2.8tdi '96
Ducati 999s '05 Monoposto
BlitZ3r
Postby íbbi_ » Fri 22. Oct 2010 12:42
ofboðslega lágt verð fyrir kit..
Postby Mr. Jones » Fri 22. Oct 2010 15:43
íbbi_ wrote:ofboðslega lágt verð fyrir kit..
Googli þið bara "vf engineering" allt um þetta þar :burnout:
    E39 540i "00
    RAV4 "96
    R6 "04
Gamalt.
    Corsa gsi
    Astra gsi
    Kadett gsi
    Calibra
    Conquest tsi
    Formula 400
    Nova SS
    Vetta pacecar
Mr. Jones
Postby íbbi_ » Fri 22. Oct 2010 17:49
já hef séð vf kit á netinu.. spjallborðum og svona, án þess að ég þekki þau nánar, en 5þús dollarar eru lágt verð finnst mér, m.a við að low budged kittin í camaroinn hjá mér eru 6þús og langt uppúr
Postby Mr. Jones » Sat 23. Oct 2010 02:01
íbbi_ wrote:já hef séð vf kit á netinu.. spjallborðum og svona, án þess að ég þekki þau nánar, en 5þús dollarar eru lágt verð finnst mér, m.a við að low budged kittin í camaroinn hjá mér eru 6þús og langt uppúr
Já já ég svosem veit ekki meira en þú, þetta lookar vel á pappír og þetta er verðið. Ég hef ekki fundið neitt neikvætt á netinu um þetta fyrirtækið.Lookar sem solid fyrirtæki.
    E39 540i "00
    RAV4 "96
    R6 "04
Gamalt.
    Corsa gsi
    Astra gsi
    Kadett gsi
    Calibra
    Conquest tsi
    Formula 400
    Nova SS
    Vetta pacecar
Mr. Jones
Postby íbbi_ » Sat 23. Oct 2010 10:47
sé að kittið í 540 er á 6k.
það er vortech blásari í þessu kitti, og ekkert sem stingur mann í augun,
en hvernig er með map?, eru e-h bensínspíssar með kittinu, eða þarftu að fara í vems e-h álíka?
edit, sé að það kemur chip með
Postby Mr. Jones » Sat 23. Oct 2010 11:15
íbbi_ wrote:sé að kittið í 540 er á 6k.
high flow OEM injectors are supplied to fit as direct replacements without modification to the injector rail. :thup:
    E39 540i "00
    RAV4 "96
    R6 "04
Gamalt.
    Corsa gsi
    Astra gsi
    Kadett gsi
    Calibra
    Conquest tsi
    Formula 400
    Nova SS
    Vetta pacecar
Mr. Jones
Postby bimmer » Sat 23. Oct 2010 19:46
Nóg af blaðri - farðu að panta.
Users browsing this forum: No registered users and 63 guests
