DIY: Skipt um gorm að aftan í E53 X5
Postby rockstone » Sun 06. Mar 2016 21:26
Þar sem ég fann engar upplýsingar á netinu um þetta, þá bjó ég þær til.
As I found literally nothing on the internet regarding this subject, I decided to take photos while I replaced mine.
Disclamer: I am not responsable for anyone that decides to use this information. Use this information at your own risk.
First, Jack up the car and remove the wheel:
Remember to put a jackstand, I put mine undir the rear subframe, then lover the jack.
Next jack under the rear till there is no stress on the strut and remove the lower bolt.
Next you need to remove the rear upper wishbone, first release the wiring and brake pipe for the holders.
Loosen the nut and the bolt that holds the wishbone.
Then the upper rear wishbone can be removed.
Time to remove the spring. To remove it since there is no space for spring clamps, I jacked under the hole thing till the spring was as compressed as i could get it, then chained it to holt it like that. That way when i released the jack the spring was a bit looser, and with a crowbar, got it out.
Then to take the chains off the old spring, I used spring clamps.
Then did the whole thing backwards, for the installation of the new spring.
rockstone
Re: DIY: Skipt um gorm að aftan í E53 X5
Postby Zed III » Sun 06. Mar 2016 21:29
þetta er furðuleg leið. Þegar ég convertaði í gorma úr púðum hjá mér var þetta næstum eins og að skipta um gorma í e30.
Var þetta svona þröngt hjá þér ?
Benedikt Guðmunds. 615-2630
Zed III
Postby rockstone » Sun 06. Mar 2016 21:36
Zed III wrote:þetta er furðuleg leið. Þegar ég convertaði í gorma úr púðum hjá mér var þetta næstum eins og að skipta um gorma í e30.
Þar sem ég vildi ekki losa neitt sem tengist hjólastillingu bílsins þá gerði ég þetta svona.
rockstone
Postby Zed III » Mon 07. Mar 2016 08:50
Held ég hafi losað eina ballance stöng hjá mér, ekkert sem kemur nálægt hjólastillingunni.
Efa það ekki að þetta hafi þó þurft hjá þér, þú ert nú betri í þessum hlutum en ég :thup: :thup:
Zed III
