Subframe- z3,compact,e30?
Postby 0812 » Tue 08. Apr 2014 21:36
Er sama subframe í z3,compact og e30??
0812
Re: Subframe- z3,compact,e30?
Postby bjarkibje » Tue 08. Apr 2014 21:56
ekki viss, minnir að það sama í e36...lofa engu samt
BMW E46 330d [SS-011]
bjarkibje
Postby thorsteinarg » Tue 08. Apr 2014 22:04
Held að það sé það sama í E30 M3, Z3 1.9L og Compact.
E36 COUPÉ 325 93' M50B25
thorsteinarg
Postby arnorerling » Sat 19. Apr 2014 16:31
E36 318ti Compact, M42, USA, AUTO (CG63) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, USA, AUTO (CG83) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M42, USA, MANUAL (CG53) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, USA, MANUAL (CG73) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316g Compact, M43, Europe, MANUAL (CH11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.6 Compact, M43, Europe, AUTO (CG21) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.6 Compact, M43, Europe, RHD, AUTO (CG22) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.6 Compact, M43, Europe, MANUAL (CG11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.6 Compact, M43, Europe, RHD, MANUAL (CG12) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.9 Compact, M43, Europe, AUTO (CS21) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.9 Compact, M43, Europe, RHD, AUTO (CS22) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.9 Compact, M43, Europe, MANUAL (CS11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 316i 1.9 Compact, M43, Europe, RHD, MANUAL (CS12) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318tds Compact, M41, Europe, MANUAL (CJ51) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318tds Compact, M41, Europe, RHD, MANUAL (CJ52) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, Europe, AUTO (CG81) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M42, Europe, AUTO (CG61) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M42, Europe, RHD, AUTO (CG62) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, Europe, RHD, AUTO (CG82) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M42, Europe, MANUAL (CG51) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, Europe, MANUAL (CG71) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M42, Europe, RHD, MANUAL (CG52) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 318ti Compact, M44, Europe, RHD, MANUAL (CG72) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 323ti Compact, M52, Europe, AUTO (CT41) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 323ti Compact, M52, Europe, AUTO (CG41) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 323ti Compact, M52, Europe, MANUAL (CG31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
E36 323ti Compact, M52, Europe, MANUAL (CT31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.9 Roadster, M44, USA (CH73) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.5 Roadster, M52, USA (CH93) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.5i Roadster, M54, USA (CN33) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Coupe, M52, USA (CK53) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, USA (CJ33) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, USA (CH33) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 3.0i Coupe, M54, USA (CK73) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 3.0i Roadster, M54, USA (CN53) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.8 Roadster, M43, Europe (CJ11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.9 Roadster, M43, Europe (CM11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.9 Roadster, M44, Europe (CH71) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.9 Roadster, M43, Europe, RHD (CM12) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 1.9 Roadster, M44, Europe, RHD (CH72) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.0 Roadster, M52, Europe (CL31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.0 Roadster, M52, Europe, RHD (CL32) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.2i Roadster, M54, Europe (CN11) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.2i Roadster, M54, Europe, RHD (CN12) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Coupe, M52, Europe (CK31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Coupe, M52, Europe (CK51) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, Europe (CH31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, Europe (CJ31) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, Europe, RHD (CJ32) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 2.8 Roadster, M52, Europe, RHD (CH32) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 3.0i Coupe, M54, Europe (CK71) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 3.0i Roadster, M54, Europe (CN51) : REAR AXLE SUPPORT/WHEEL SUSPENSION
Z3 Z3 3.0i Roadster, M54, Europe, RHD (CN52) : REAR AXLE SUPPORT/WHEEL SUSPENSION
er samt nokkuð viss um að það sé það sama í e30
Arnór Erling.
E28 5xxi '84 - Drift Project M50TURBO
arnorerling
Postby Angelic0- » Sat 19. Apr 2014 21:50
Það er sama í E30...
Postby Alpina » Sat 19. Apr 2014 23:06
Er ekki feitt svalt er menn verða sér úti um Z3 M/// subframið.. í E30.. hef lesið það
