BMW ///M recomended olíur
Postby fart » Tue 15. Oct 2013 11:53
BMW núna farnir að mæla aftur með 5W30, eftir að hafa eingögnu selt 10W60 í töluverðan tíma.
BMW CURRENT LISTING OF SYNTHETIC OILS (US Market)
Required maintenance work or services should be performed for your vehicle by your authorized
BMW center.
BMW High Performance Synthetic Oil is recommended for scheduled engine oil changes.
BMW Genuine Oil SAE 5W-30 Synthetic Oil*
* Does not apply to M vehicles - see below for further information
BMW part number 07 51 0 017 866 – 12 x 1 qt case
BMW part number 07 510 038 678 – 24 x 1qt Enviropack
BMW part number 07 51 0 017 954 – 55 gallon drum
BMW recommends that you check your engine oil level whenever you add fuel to your vehicle.
If you need to add oil between oil changes and BMW High Performance Synthetic Oil is unavailable,
visit your nearest authorized BMW Center. For information on checking your engine oil level refer to
your vehicle’s Owner’s Manual.
The choice of the right SAE grade is based on the climatic conditions in the region in which you
normally drive your BMW.
To best determine which SAE grade is best suited for your vehicle contact an authorized BMW center.
*The following is the only recommended and approved synthetic oil for BMW M (Motorsport)
vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils
for BMW M vehicles equipped with S54, S62, S65 or S85 engines
or
Castrol Edge Professional OE 5W30 Synthetic Engine Oil
BMW part number 07 51 0 037 195
The following is a listing of synthetic oils recommended and approved for use in the BMW B7 ALPINA
in the US market:
Reyndar telja þeir ekki upp S50B3x eða S38B3x
Re: BMW ///M recomended olíur
Postby gardara » Tue 15. Oct 2013 13:05
Er þetta ekki bara bissness? Castrol eiga núna nóg 5w30 sem þeir þurfa að koma út :lol:
1974 BMW 1802
1994 BMW E36 332i sedan
2008 BMW E92 335i
2013 BMW F30 320d
Postby slapi » Tue 15. Oct 2013 22:57
S38 og S50 eru á LL-98
Postby Alpina » Sat 19. Oct 2013 21:58
slapi wrote:S38 og S50 eru á LL-98
Var ekki S38 á 10/60 alltaf i den ????????'
Postby Angelic0- » Sat 19. Oct 2013 23:16
Það var tag á RO119 sem að var víraður við háspennukeflið.... Castrol TWS 10w60 ONLY
Postby sh4rk » Sun 20. Oct 2013 00:29
Humm ég runnaði mína S38 á 10/40 en revaði hana sjaldan
Siggi
E23 735i
E32 740i 6 spd 8)
E38 740d
E32 735i Shadowline Seldur
E32 740i Seldur
E32 740i RIP
sh4rk
Postby slapi » Sun 20. Oct 2013 06:32
TWS kom ekki fyrr en S54 kom
Postby fart » Sun 20. Oct 2013 06:38
Límmiðar koma gjarnan eftirá
Slapi, á maður að fara í Mobil1 5W30 næst. Ég er að fara að skipta um olíusíuhúið fljótlega. Svo er spurning hvort að það er betra að ég steli olíu fyrir túrbínurnar frekar úr Olíuhitanum frekar en þrýstingnum. Ég er ekki frá því að það sé töluvert meiri blár reykur sem kemur stundum á Overrun eftir að ég setti báðar bínurnar á olíuþrýstingslínuna.
Postby slapi » Mon 21. Oct 2013 11:05
Ég myndi prívat og persónulega ekki nota neitt nema TWS á þessa mótora.
Hitaþolið er meginn þátturinn í þessu.
Postby Logi » Mon 21. Oct 2013 21:15
Í Owner's handbook fyrir M5 '90 stendur:
Oils must be of viscosity class SAE 15W-40 / 15W-50.
The stated temperature limits may be departed from, but only for brief periods.
BMW Motorsport GmbH recommends the use of Wintershall Viva 1 engine oil.
Logi
Postby fart » Tue 22. Oct 2013 08:25
slapi wrote:Ég myndi prívat og persónulega ekki nota neitt nema TWS á þessa mótora.
EDGE þá líklega hérna..
En af hverju að fara þá ekki í 5W30 Edge frekar en 10W60 fyrir mig t.d.?
Postby Angelic0- » Wed 23. Oct 2013 01:33
TWS olían heitir
Castrol EDGE TWS hérna...
TWS er allt önnur olía....
Myndi frekar nota 5W30 mótorhjólaolíu þá þar sem að þær eru hannaðar á mótora sem að geyma oftast ekki mikið magn og því hitna þær olíur meira og þola hitann betur...
Postby íbbi_ » Wed 23. Oct 2013 02:08
bmw mætti beina kröftum sínum aðeins meira í að láta þessa fínu mótora brenna og leka aðeins minna af þessum líka rándýru olíum sem þeir krefjast af manni að nota,
Postby Angelic0- » Wed 23. Oct 2013 02:32
íbbi_ wrote:bmw mætti beina kröftum sínum aðeins meira í að láta þessa fínu mótora brenna og leka aðeins minna af þessum líka rándýru olíum sem þeir krefjast af manni að nota,
Hef allavega aldrei lent í veseni með 10W60.. en ég var aðeins á VT193 þegar að hann var keyrður á 5W30 Castrol EDGE og það var alveg hræðilegt að bæta við 2 lítrum af olíu í hvert skipti sem að maður tók bensín :lol:
Postby fart » Thu 24. Oct 2013 11:40
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles
Þetta er s.s. sama og BMW LL-01 sem er mælt með á nýrri Sxx vélarnar, og 5w40 er þykktin sem ég á að nota á S50B3x skv.. mörgum aðilum á netinu
Þessi er einmitt 5w40
eða
5w40 fyrir minn
Frekar áhugavert allt saman
Spurning hvort að 10W60 sé hreinlega of þykk við 100°c.. ?
Users browsing this forum: Google [Bot] and 15 guests
