tímakeðju skipti ?
tímakeðju skipti ?
Postby Aron123 » Fri 05. Oct 2012 01:33
veit einhver hvenar þarf að fara huga að tímakeðju skiptum í e36 323 ? s.s m52b25
BMW E39 02' ///M5 [OK044]
BMW E60 05' ///M5 [OD896]
Seldir
Range Rover vogue 04' [VA038]
BMW E39 ///M5 [AP868]
BMW E39 ///M5 [VI232]
BMW E39 ///M5 [YS163]
BMW E36 ///M3 95' [MR159]
BMW Z3 Coupe 99' [ME157]
Aron123
Re: tímakeðju skipti ?
Postby srr » Fri 05. Oct 2012 01:43
Samkvæmt leit um þetta,,,,
"Longer than the car usually...
You should only replace the chain if you're already in there to replace the cam sprockets or Vanos (usually becuase of noise/rattle associated with excess wear) - or perhaps as a preventative measure if the head is already off for some reason.
On a properly maintained M52 - this should really never have to be done as part of regular maintenance. "
Postby Aron123 » Fri 05. Oct 2012 04:07
srr wrote:Samkvæmt leit um þetta,,,,
aa okei :) takk fyrir þetta
Seldir
Aron123
