Stór Aksturstölva í E36
Postby Gunnar Hnefill » Wed 21. Mar 2007 12:25
hvernig breytir maður 18 takka aksturstölvunni í e36 úr þýsku yfir í ensku ? ég hef fengið nóg af því að sitja útí bíl og lesa heilu ritningarnar uppúr þýskri orða bók. held að það sé bara best að hafa þetta á ensku og ekkert vesen :wink:
Gunnar Hnefill
Postby Aron Fridrik » Wed 21. Mar 2007 12:27
Tekið af: http://www.m5board.com/vbulletin/archiv ... -6767.html
Getting into the Test Codes:
Push OBC buttons 1000 and 10 together. You will see the word Test. By pressing a combination of the 10 and 1's you can enter Test Codes from 1 to 21. After entering the number press R/S and you will get a continuous display of the test function. To cancel, just press any of the OBC function keys.
List of Available Tests:
Test Number Description
1 Display Test (all LCDs and LEDs activate)
2 Current Consumption in litres / 100 km
3 Current Consumption in litres / hour
4 Average consumption (used in calculating range)
5 Current Range
6 Not used (this function is active on some, but not sure of the purpose)
7 Fuel Remaining in Tank (litres)
8 Current speed (km/h)
9 System Voltage at Terminal R
10 Country / Language
11 Units / am.pm
12 Average speed (km/h) for calculating ETA
13 ETA
14 Date of software / mask of OBC
15 Production Diagnosis
16 Production Diagnosis
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous vs. intermittent)
19 Lock / Unlock all functions (Sum of month and date to unlock or lock)
20 Correction Factor for OBC Fuel Consumption
21 Reset all defect codes, date and time
Postby mattiorn » Wed 21. Mar 2007 12:27
Ef þú hefðir skoðað póstana fyrir neðan þá er þetta þar :wink:
http://www.bmwkraftur.is/spjall/viewtopic.php?t=20996
mattiorn
Postby mattiorn » Wed 21. Mar 2007 12:28
DEEEEEEeem ég var á undan :evil:
mattiorn
Postby Aron Fridrik » Wed 21. Mar 2007 12:31
hahaha.. 8)
Postby mattiorn » Wed 21. Mar 2007 15:56
Ekki nóg með að þú stelir mínu svari, heldur hlærð svo af mér!
:squint: :bawl:
mattiorn
Postby Einari » Thu 22. Mar 2007 22:48
nei Matti...hann hlær AÐ þér :wink:
Einari
Postby iar » Sat 14. Apr 2007 20:43
Sælir.
Hefur einhver hér stillt eyðslumælinn í OBC tölvunni skv. þessum leiðbeiningum? Ég hef tekið eftir að það er nokkuð föst skekkja (ca. 6-7%) hjá mér í OBC og því sem ég reikna m.v. akstur og bensínkaup og það væri gaman að geta stillt þetta af svo OBC sé að sýna nokkuð rétta tölu. Hefur einhver gert þetta eða er þetta kannski of lítil skekkja til að laga?
aronisonfire wrote:Tekið af: http://www.m5board.com/vbulletin/archiv ... -6767.html
http://www.m5board.com/vbulletin/archive/index.php/t-6767.html wrote:How to correct your fuel consumption readout:
If your car is anything like mine, the fuel consumption readout will be way out. But it can be adjusted! First, you need to measure your fuel consumption as accurately as possible, by filling up the tank, driving until nearly empty, filling again, and figuring out your fuel consumption, in either litres / 100 kms, or MPG. At this point, also note what the fuel consumption as reported by the OBC is. You need both figures to make the adjustment. Once you have that accurate figure, follow the following procedure:
Unlock the OBC as described above.
Go to test 20.
This is the existing fuel consumption constant used in the calculation.
Find the ratio between the old consumption reading, and the actual consumption reading:
For litres per 100kms, this is the actual consumption divided by the reported consumption.
For MPG, it is the opposite. Ie. It is the reported conumption divided by the actual consumption.
Now multiply that ratio with the existing fuel consumption constant, the result is the new constant.
Simply type in the new constant, and press S/R NOTE: Some claim that for some reason, if you don't drive your car for a day or two, the constant will reset back to 1000.
Til gamans þá er reiknuð bensínnotkun vs. OBC bensínnotkun hjá mér síðustu mánuði svona: :-)
Postby ValliFudd » Sun 15. Apr 2007 00:35
iar wrote:Til gamans þá er reiknuð bensínnotkun vs. OBC bensínnotkun hjá mér síðustu mánuði svona: :-)
hehe, það er alltaf jafn magnað hvað þú heldur vel utan um svona hluti :lol:
ætla að leyfa mér að skjóta á að toppurinn á þessu hafi verið þegar leikdagar voru?
ValliFudd
Postby ///MR HUNG » Sun 15. Apr 2007 00:44
Hver mælir eyðslu :lol:
///MR HUNG
Postby Alpina » Sun 15. Apr 2007 08:06
///MR HUNG wrote:Hver mælir eyðslu :lol:
Nískupúkar :P :P :P :P :P
Postby iar » Sun 15. Apr 2007 10:31
Þetta er reyndar ekki nema frá ca. áramótum. :-)
Mig grunaði reyndar að þetta færi í rugl ef ég póstaði myndinni en aftur að spurningunni, hefur nokkur stillt eyðslumælinn í OBC?
Ég vil helst ekki tjá mig um nískubullið frá hr. Buchloe enda eru mælingarnar ekki spurning um peninga heldur er frekar verið að svala ákveðnum talnanördahvötum. :P
Postby Eggert » Sun 15. Apr 2007 12:14
Það vantar alveg kvarðann á þetta graf hjá þér, svo maður sjái raunverulega muninn. Það er auðvelt að blekkja, hvort sem er vísvitandi eða óvart, með mismunandi kvörðum.
E53 X5 4.4i
Eggert
Postby iar » Sun 15. Apr 2007 13:27
Já sko efri línan er með Cyclone en sú neðri án Cyclone. :tease:
Grafið skiptir engu. Munurinn er eins og ég sagði 6-7% og grafið (sem er jú klippt neðan af) bara sett til gamans til að sýna hversu constant munurinn er á iar mældri eyðslu vs. OBC mældri eyðslu.
Postby Aron Fridrik » Sun 15. Apr 2007 13:29
hahahaha.. með og án cyclone.. :rofl:
Users browsing this forum: No registered users and 67 guests
