Hvernig opnar maður e32 með rafgeyminn í skottinu ?
man eftir þræði hérna einhverntímann en finn hann ekki
Unlocking procedure: ( Procedure courtesy of "the Master" Bill R. )
1. Insert the master key into the front right door.
2. Pull up the door handle.
3. Turn the key counterclockwise to emergency unlock position 1.
4. Open the door.
5. Close doors and turn the right front door lock to the synchronize position 5.
This is for the driver door. The passenger door is the mirror image of the picture
If you cannot do it, try Stewart Ebrat's trick taking the truck light bulb out and connecting the positive jumper cable to it. Now the car has power to open it.
