BMW e39 : spólvörn(ASC/DSC), ABS og bremsu ljós í mælaborði
Re: BMW e39 : spólvörn(ASC/DSC), ABS og bremsu ljós í mælab
Postby Atli885 » Sun 07. Apr 2013 13:42
íbbi_ wrote:rásina fyrir abs skynjarann í plögginu á tölvuni. til að sjá hvort það sé heilinn sjálfur eða skynjari sem er farinn
þetta plögg er það ekki?
INTERPRET DIODE-TEST RESULTS:
- If the DMM, in diode mode, reads infinity ("OL") in both directions, you've got a bad sensor or circuit
- If the DMM, in resistance mode, reads much greater than 7Mohms, you've got a bad sensor or circuit
- If all 4 sensors read OK, it's most likely the ABS control unit.
- If you think you found two bad sensors, you probably messed up.
- Rarely is the cause due to bad steering angle (yaw/lew) sensors
- Rarely is the cause due to a bad hydro unit
- The problem is almost always a wheel rotation sensor or the ABS control unit
Atli885
