Sæti án loftpúðaskynjara í E36
Re: Sæti án loftpúðaskynjara í E36
Postby slapi » Sun 30. Jan 2011 16:25
By-pass modúlarnir eru einmitt ekki þannig því þá myndu ameríku bílarnir alltaf pípa á farþegann að fara í belti
Postby gunnar » Sun 30. Jan 2011 16:31
Skil þig,
Skv. sölusíðu á Ebay fyrir svona bypass unit þá virkar þetta svona :
The PASB Unit tricks the cars SBE into thinking that the passenger occupancy sensor mat is operational, this allows the SRS Air Bags to work 100% correctly.
The only point having a seat sensor is that the airbag won't deploy when the passenger seat is vacant, thus saving on repair costs (although if the accident is serious enough to have the Air Bags deployed, the vehicle would most likely be a right off anyway).
At present if your Airbag light is constantly on, there is a chance that the air bags will not deploy on impact!
This Unit just connects to two wires under the passenger seat.This job will take a complete novice less than 5 minutes (if you can change a plug you can do this).
