Postby fart » Wed 14. Feb 2007 17:50
gstuning wrote:Meira að segja notan non M3 gaurar E500 diska redrillaða.
Verst gæti verið að fá nógu góðann adapter, enn það getur vel verið að þú getur hreinlega keypt hann beint frá Brembo eða látið verkstæði búa hann til,
verður að fylgjast með offsettinu líka,
diskarnir gætu ekki passað ef offsettið er allt annað á SLR.
enn það kemur bara í ljós bráðlega ekki satt ;)
Jú. Eftir svona 2-3 vikur, ég verð á ferðalagi núna í viku þannig að ég næ ekki að fara með hann fyrr en þá. Auk þess þarf ég að kaupa 18" felgur fyrst, þannig að ég geti keyrt heim.
Hver hefði haldið að SLR kæmi orginal með 18"... allavega ekki ég.
Varðandi ON/OFF virkni bremsanna
Unfortunately, the brakes do not match the handling. On paper, ceramic discs, 370mm front with 8-piston calliper, 360mm rear with 4-piston calliper seems to be a winning formula. Yes, they are really powerful and fade-free under hard use, but the pedal is unusually difficult to modulate. All is blame to the complicated, brake-by-wire, Mercedes Sensotronic Brake Control. SBC has been used in the SL-class quite well, but in the higher performance SLR and mates with ceramic brake discs it is simply disastrous. As there is no hydraulic linkage between brakes and pedal, as it measures only the pedal travel to determine brake force, the pedal feel is always soft and the driver cannot feel the exact state of braking. As a result, you can easily overbrake or underbrake the car. If you want to stop the car hard, that’s fine, just press the pedal to the bottom. If you want to slow down the car into a corner, you will find it is very difficult to apply the braking smoothly, blame to the lack of pedal feel and the poor calibration of the system.
I can’t believe Gordon Murray needed SBC. A conventional hydraulic braking system is just fine and save weight, why bother with an unnecessary technology? he must thought so. Unfortunately, the German might think otherwise. They want to show more technologies to their customers - seems that ABS, ESP, DSC and "air brake" are not enough to them.
Ekkert SBC (sucker brake control) á 1995 BMW
Postby íbbi_ » Wed 14. Feb 2007 17:52
slr fæst bæði á 18 og 19" orginal og það eru sithtvorar bremsurnar undir þeim
Postby fart » Wed 14. Feb 2007 18:03
íbbi_ wrote:slr fæst bæði á 18 og 19" orginal og það eru sithtvorar bremsurnar undir þeim
Jamm, regular SLR og 722, 722 kemur á 19" ekki c.a. svona.
Postby elli » Wed 14. Feb 2007 18:07
Velkominn aftur.
Þetta er þrusu flottur bíll. Vonandi á hann eftir að reynast vel (efast ekki um það).
Þessir E36 M3 stólar eru ekkert smá djúsí alltaf.
Elli M1 fan
E32 750I '91 >
elli
Postby iar » Wed 14. Feb 2007 19:38
Eðalmeðal!! Til lukku með gripinn! :clap:
Postby Stefan325i » Wed 14. Feb 2007 19:39
Til hamingju með geggjaðnn bíl. 8) 8)
E30 S50B32
X5 3,0i ´02
Artic Cat ZR500 ´98
GSTuning
Stefan325i
Postby Aron Andrew » Wed 14. Feb 2007 19:48
Til hamingju!!
Klikkuð græja 8)
Postby Raggi M5 » Wed 14. Feb 2007 20:40
Ég er ekki alveg með hérna,,, afhverju velkominn aftur???
En til hamingju með heavy svalann M3 8)
Þetta er orðin ansi rennilegur floti hjá þér :twisted:
E39 525d Touring ´03
Toy Yaris T-Sport ´02
Yamaha R1 ´05
Raggi M5
Postby bimmer » Wed 14. Feb 2007 22:19
Raggi M5 wrote:Ég er ekki alveg með hérna,,, afhverju velkominn aftur???
Fart fór í smá sjálfskipaða útlegð á Blýfót en er kominn heim aftur :)
Postby Sezar » Wed 14. Feb 2007 23:53
Virkilega töff 8)
Sezar
Postby Kristján Einar » Thu 15. Feb 2007 00:16
geggjað, til hamingju! :twisted:
Kristján Einar
BMW 2002 Turbo ´75[/url]
Kristján Einar
Postby BMWaff » Thu 15. Feb 2007 02:01
Þetta er rosaalegt! Til hamingju.. En verð að vera sammála sumum hér... Þetta er rosalega ljótur litur, en rooooooosalega flottur bíll engu að síður!
Race on!
Núið:
BMW 730d '04
BMWaff
Postby fart » Thu 15. Feb 2007 08:21
Eitthvað eru upplýsingarnar misvísandi varðandi hvaða felgustærð ég get notað.
Skillst að ég geti notað sumar 18" felgur, en annars 19".
það góða er að bremsurnar eru lagðar af stað til mín. Eina sem ég get gert er að fara með diskana í felguseljendur og mátað.
Postby Gunni » Thu 15. Feb 2007 09:26
Mér finnst svo fyndið hvað sumir hata þennan lit.
Mér finnst hann kúl, fer bílnum vel 8)
En þessar bremsur verða :shock: geggjaðar.
Ertu kominn með einhverjar hugmyndir um felgur, eða þarftu að bíða eftir
bremsunum til að sjá hvað stendur til boða og velja svo úr því ?
Gunni
Postby jonthor » Thu 15. Feb 2007 09:34
Magnaður bíll, til hamingju!
jonthor
Users browsing this forum: No registered users and 88 guests
