Bilstein PSS9 coilovers fyrir E36
Postby gardara » Sun 11. May 2014 17:15
Er með til sölu notað sett af Bilstein B16 PSS9 coilovers fyrir E36.
Fyrir þá sem ekki þekkja þá er þetta coilovers með gasdempurum og hægt er að stilla stífleikann á dempurunum ásamt því auðvitað að stilla hæðina á kerfinu. Það er lífstíðarábyrgð á þessu frá Bilstein.
Þetta er eitt það al besta sem hægt er að fá fyrir E36 :thup:
  • Monotube shocks and struts
  • 9-stage precise compressing and rebound settings
  • Threaded Body for Accurate Adjustability
  • Front and Rear Progressive Springs
  • Bilstein's Patented Triple-C-Technology Coating for Long Lasting Corrosion Re
  • Front Lowering Range: 30-40mm
  • Rear Lowering Range: 30-40mm
Bilstein's celebrated PSS9 coil over kit for the E36 M3 combines height adjustment struts with Bilstein's 9-position monotube shock absorbers. The PSS9 coilovers offer a stiffer spring rate than stock and a lower ride height for less bodyroll and better handling. These are among the easiest coil over kits on the market - no special mounts required (works with stock mounts and sway bar links), larger adjustment knob allows for easy shock damping changes, and coil over spanner wrenches included for easy height changes. Bilstein backs up their technology with a limited lifetime warranty. TUV approved for fitment, safety, and quality!
The fitment of these is just like a standard shock and spring package. The front struts and rear shocks are compatible with the stock strut and shock mounts. You can re-use your own or choose a mount with additional features. Because the Bilstein design keeps the sway bar tab in the original location, you can re-use the stock sway bar links. Using the stock mounts keeps the cost and complexity down and allows for TUV certification. You can also be assured of the stock mount's quiet and long-lasting performance. The assembly of the front strut is the same as a the factory strut. In the rear, ride height is made by an adjustable spring perch that sits under the rear spring. Install instructions and diagrams included.
Ride height adjustments are done from perches that ride on the front strut body. These struts are zinc coated for excellent wear and corrosion resistance. You can set the ride height between 1.0 to 1.75 inches lower than stock ride height. On the E36 we recommend a front to rear rake of .75" (higher rear). Spring rates are - 460lb in front and 685lb (progressive) in rear. These are stiffer than most coil over kit manufacturers and the results of Bilstein's extensive testing on the German Nurgburgring and Autobahn. The lower spring is a 60mm inside diameter so hardware is already in place if you would like to change 60mm springs later on.
Bilstein's monotube shock dampers in the PSS9 offer 9 precise settings for compression and rebound. A new setting is just a click away, allowing you to set a ride and handling combination that works for your setting. Instead of offering too many shock settings that you're never going to use, Bilstein has chosen nine optimal damping curves from a smooth street setting (P9) to an ultra-stiff track-only setup (P1). Shock changes are made from the over-sized adjuster knob at the bottom of each strut or shock - no special tools, no cutting of interior panels, and no hassle. You don't even have to raise the car to make adjustments.
Customer impression: "Kevin and Dave, Everything that was worked on is better: The UUC is shorter and operates smoother and with less effort, the brakes don't squeek and now can be modulated, the mid range (4500 plus) is stonger. Now for the biggest improvement, the PSS-9's. The car centers and tracks MUCH better, is more connected and above 20mph is "smoother". Inshort it is a diff. car. How is it possible for the coil-overs to have that much of an affect, and I have yet to track it. Was there something wrong with the stock equipment? Do you align to diff. specs that work better? Or is the stock suspension just not good? To sum it up, I'm impressed with how much better my M3 is after the work that was done." - Doug (local customer)
If you're looking for a supremely capable and high quality suspension, then look no further than the Bilstein PSS9. It combines all of the best German engineering with real-world development, and a lifetime warranty.
Leiðbeiningar um ísetningu: http://home.comcast.net/~matthew.c.smith/mods/PSS9/
Það er hægt að semja um að ég setji þetta í hjá kaupanda ef þess er óskað.
Svona sett kostar 450þ kr hjá Poulsen
Listaverð á þessu er 1800EUR úti
Ég er opinn fyrir tilboðum en verðhugmynd er 250þ
██ 1974 BMW 1802
██ 1994 BMW E36 332i sedan
██ 2008 BMW E92 335i
██ 2013 BMW F30 320d
Re: Bilstein PSS9 coilovers fyrir E36
Postby Geir Elvar » Mon 12. May 2014 00:08
Þetta er alvöru dót!
E39 - Daily
Geir Elvar
Postby ANDRIM » Mon 12. May 2014 11:38
bara í lagi , en hvar er stífleika stilling á demparum?
Andri Már
andri_mar@simnet.is
-BMW E46 323ic Daly
-BMW E36 325is Drifter
-Pocket bike Winter beater
-BMW E34 525ix Daly (SELDUR)
Auglýstu varahlutina þína á http://PARTALISTINN.IS
ANDRIM
Postby gardara » Wed 14. May 2014 06:11
Thad eru hjól nedan á dempurunum, thau sjást á myndunum, sérd gyllt hjól nedarlega á afturdempurunum og á framdempurunum sérdu bláa plasthlíf nedst á demparanum yfir stillihjólinu
██ 1974 BMW 1802
Postby Angelic0- » Sun 18. May 2014 04:50
vá, want this !
Postby gardara » Wed 16. Jul 2014 13:16
Bump!
██ 1974 BMW 1802
Postby Angelic0- » Wed 16. Jul 2014 15:57
Hef ekið MUSTANG með svona.... og hann bara höndlar feitt :!:
TRUE STORY :!:
Postby flamatron » Wed 16. Jul 2014 17:36
Er með svona í mínum.. Mjög skemmtilegt kerfi! :thup:
Tómas
BMW 325ic '95
Isuzu Trooper '99
flamatron
